Tables display error after 2024.2 update
Chuck_L_AKS
Chuck_L_AKS
I am having a problem with some table styles in 2024. They are not printing at the correct scale.
This issue was present in 2024.1, 2024.1.1 and is again in 2024.2 updates.
DWG is attached any help is appreciated.
Thanks!
ChuckL
In model space:
On the layout tab(paper space):
Print preview and the same result of printing and publishing:
Chuck Litchfield
AKS Engineering and Forestry, LLC
C3D 2024
tcorey
I was only able to make those preview at the right scale by exploding the tables before Preview. It doesn't seem like a long-term solution, but it will help you output your pdf today.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Chuck_L_AKS
True, this is a solution to make these print. But, I think we need an application fix.
Or is there a table style configuration option I should use? These work fine in 2022.
Chuck Litchfield
C3D 2024
Chuck_L_AKS
I found a solution. Change the Visual Style of the viewport from 2D Wireframe to Wireframe
I am not certain if there is something in my table styles that addresses this, but this is a solution that works.
Accepting my own solution seems strange. But sharing the solution is better for all.
Chuck Litchfield
C3D 2024
DeaconDave
Has there been another solution determined for correcting this issue?
David King
Civil Designer
C3D 2014 SP2
C3D 2015 SP3
C3D 2018 SP2
Win 7 Pro - 64 Bit OS
Intel Xeon CPU E5-1603 @ 2.80 GHz
8 GB RAM
NVIDIA Quadro 600
Chuck_L_AKS
This was corrected with an update to C3D 2024.3 update and an update to AutoCAD 2024.1.3 as well. There were more corrections C3D 2024.4 updates to address other issues.
Chuck Litchfield
C3D 2024
