Table style field is greyed out in insert table dialog box
brettS6K2S
brettS6K2S
A user is experiencing an issue when attempting to insert a table using a data link.  The field for the Table Style in the upper left is greyed out on his computer. I can open the same file and everything works as it should.
They have tried recreating the data link, exiting the program, rebooting, etc...  Any suggestions?  I'm sure it's some silly little box or option checked or unchecked.
rl_jackson
The link defines the table. Which can then be edited in the right portion of the dialogue.
You could always set the default style using TABLESTYLE perhaps.
Rick Jackson
Survey CAD Technician VI
brettS6K2S
After all this, the user let me know that they weren't selecting the proper style.
Once they selected a different style from the drop down, all was good.
ecfernandez
Hi @brettS6K2S, I read your post before and did not understand it, nor know how anything that could help. So, thanks for sharing what was happening with your drawing.
Best regards!
Camilo Fernández
Civil engineer | Specialist in design, construction, and maintenance of roadways
LinkedIn
