Table layout
Table layout
topografiaFMTR6
Table layout
topografiaFMTR6
Hello, i want to make a table of a polyline (or similar object) that gives me:
  1. Columns:
    1. "Name" of vertice polyline;
    2. Latitude;
    3. Longitude;
    4. Forward segment azimuth;
    5. Forward segment length;
  2. Lines:
    1. Vertice 1 "name";
    2. Vertice 2 "name";
    3. Vertice n+1 "name";
    4. ...
For example, the vertices can be defined as cogo points and used "points name" for vertice identification, no problem with that.
I tried parcels and alignments, with no results.
Sean_Fahey_10
This sounds like something Dynamo might be able to create for you
You can bring in the polylines, grab the vertices and give those names, etc.
nkiakas
Hi @topografiaFMTR6
Agreed with @Sean_Fahey_10
This is Dynamo workflow
Regards
topografiaFMTR6
I m not familiar with Dynamo, you recommend any content?
Sean_Fahey_10
I would offer the following sites:
I don't know what information you are trying to convey for client/contractor/etc. but Dynamo can help you with this approach to help automate the task instead of manually enter the data you want.
nkiakas
Hi @topografiaFMTR6
Are you looking something like the attached?
Regards
