Table Cells showing three question marks due to no information, wanting it to show nothing rather than the "???"
jed_martin8EQHL
Observer Observer
jed_martin8EQHL
Observer
Observer
I need to be able to change the "???" to just display as nothing when there is no information required.
Is there an easy way to do this?
I don't want to have to change the part itself due to compatibility issues.
I need the length/width for rectangular manholes and the diameter for circular manholes.
Any help would be appreciated.
MMcCall402
You might try combining those 3 columns into one, "Size", then use structure Description to hold and supply the structure size that should show in the table.  (1200 Dia., 675 x 750, etc)
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
jed_martin8EQHL
Observer
Observer
Hi Mark, thanks for the reply.
Unfortunately I am already using the Structure Description for the Status of the Manholes
RobertEVs
I don't have the time to try this but what if you create an expression with an if statement that if some number is less than it returns very tiny text or invisible. In this example I have an expression where I tell my profile to only label anything over 10%. Anything under that and Civil sets the label invisible size wise. This may work in your table label configured to your desired callout.
IF({Tangent Grade}<=.5&{Tangent Grade}>=0.1,0.008,0)
Throwing this out there.
tcorey
Civil 3D Tables don't support Expressions.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Cadguru42
I'd try to use Project Explorer to create the table instead. That way you get an AutoCAD TABLE object and can at least edit it. But if the design changes (which we know never happens and Autodesk thinks never happens) then any manual edits to the table have to be redone. So it's semi-dynamic, but at least you get an object that can be edited unlike the 20 year old pipe network tables.
C3D 2024-2026
Windows 11
32GB RAM
