Sweep 3d polyline from given rectangle
met1ns
met1ns
Hello!
I have bunch of 3d polylines which I wanna turn into 3d solids.
If I draw a rectangle which I sweep from, which  point of the rectangle gets the correct Z value? Top, midd or bottom? Is there a way to chose?
My 3d polylines are 0,55m below my surface. I want the top of the 3d solid to be 0,55m under surface and the bottom 0,85m. So the 3d solid is 0,3m thick.
Thank you,
BrianHailey
The centroid of the object being swept will follow the path of the sweep.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
