Civil 3D Forum
Survey Points
8 REPLIES 8
Message 1 of 9
467 Views, 8 Replies
Survey Points
Can anyone help me with survey points.  I have multiple drawings set to the same working folder with points in each drawing, how do I keep the point numbers correct? How do I keep point numbers form writing over each other when I insert them into the same drawing? To clarify the issue I need point number to start numbering from the last point in a drawing without the points being inserted into the current drawing.
William
Survey Points
William
8 REPLIES 8
Message 2 of 9
wfberry
wfberry
Perhaps I am not quite following you here.  If you have Drawing No 1 points ending with 10323,  In Drawing No 2 renumber points starting with 10324.  This is done by adding or subtracting "all" beginning with the lowest number in Drawing No. 2.
Bill
Bill
Message 3 of 9
ESchomberg
ESchomberg
I am sorry but your post is a bit confusing to me.... I do not quite understand your situation or question
Message 4 of 9
rl_jackson
rl_jackson
Use a survey database if there all part of the same project on the same coordinate system
Rick Jackson
Survey CAD Technician VI
Rick Jackson
Message 5 of 9
TerryDotson
TerryDotson
If you were to consider third party software and need a tool to quickly report the points used (and unused) in multiple drawings, along with details of any points duplicated (and in which files), take a look at the Point Harvest tool in C3D Point Tools.
Message 6 of 9
in reply to: TerryDotson
What is the second group of points going to be used for that you don't want to add them to the drawing.
I have in the past created a new file and xrefed it to the original file. That way I can see the location of the 2nd group and not have them in the first file.
Dave Z.
The old geezer
Dave Z.
The old geezer
Message 7 of 9
in reply to: rl_jackson
I use a survey database to view all the points in the project, but some of the points groups are from different drawings in the project. The current drawing in the project database has only the points from that drawing. I want to create new points in the current drawing but not have it overwrite the points from other groups in the database when I bring them in to that current drawing. This was not an issue in 2004 because all the points were in the project database and it would not let you write over preexisting point numbers.
Message 8 of 9
Message 9 of 9
rl_jackson
rl_jackson
If I'm understanding you correctly, they problem lies in the fact the the SDB is not linked to the drawing in Civil 3D. There totally disconnected, unlike (bad word) LDD projects.
Rick Jackson
Rick Jackson
Rail Community
