Survey Figure Style issue
Guilima
Message 1 of 10
Guilima
Greetings everyone,
I am facing an issue when working with linework. When I import the data to the survey database and process the linework, the figure with code Barraca are the only ones that assume the figure style configured by the figure prefix database manager and the rest of them assume the basic style. I would like to understand what is happening.
Replies (9)
Message 2 of 10
rl_jackson
Without seeing your complete figure prefix database. My guess would be that you have a similar code that is in conflict with that code, or there is something that is in conflict with the figure style.
Rick Jackson
Survey CAD Technician VI
Message 3 of 10
Guilima
May I share my figure prefix database?
Message 4 of 10
rl_jackson
Sure, it's either the Prefix Database or it could also be a description key that's in conflict with it also. That doesn't happen as often, but it does happen.
Rick Jackson
Message 5 of 10
rl_jackson
Let me add a little additional information regarding this subject, which may help you solve this problem.
First, is a simple one they call this a Figure PREFIX Database, a prefix is generally short for the initial characters (i.e. EP, EC etc.) by limiting the characters and maintaining case as prefixes are case sensitive, just as description keys are ultimately limits the room for error (upper or lower it really doesn't matter, being consistency does). This in-turn makes data collection by you or the field crew more fluent. Who wants to spell the entire word, when it can be truncated in some fashion that is understandable, gets the point across and meets the end goal of obtaining linework.
Second, Description KEYS act and do very similar things and go hand and hand with the PREFIXs. You can use them to further determine what layer your point resides on, or how that point will display the data just as the PREFIX. As a general rule I use KEYS for symbology and PREFIXs for linework, but that's not a rule that is set in stone, use it how you want to (use one or both at the same time), at the end of the day the most import thing is get the job out the door.
Finally, I'm sure you're trying to set things up to run like a well-oiled machine. Trust me in knowing this is not an over-night sensation. You don't sit down one day and make up 200 symbols with codes and the next day come in and import the data into the drawing and ta-da! it's all there. Same as you don't get 6 linetypes for different types of fences to appear on one layer based on the figure code. There is no EASY BUTTON up in here!
HTH
Rick Jackson
Message 6 of 10
Guilima
At the link below I share the .dwg file with description keys, .txt file with a sample of data, the linework code set and figure prefix database.
https://mega.nz/folder/60FSxKrK#mfd9rBUwbQQf1mem2DVnIghttps
Message 7 of 10
rl_jackson
Your problem is consistency. If the description the .txt file is all CAPS you FIGURE must be as well.
Attached FDB should solve the problem.
Rick Jackson
Message 8 of 10
Guilima
Thank you for your patient @Anonymous.
Your attached database work, but i have another issue that is: the figure assumes all propriety except the layer color.
Message 9 of 10
rl_jackson
Go to your figure style verify that it goes to Layer 0, and then make sure that color is By Layer.
The figure Prefixe should state that it goes to 0 - Ved.....
This should resolve the issue.
Rick Jackson
Message 10 of 10
Guilima
The problem was in the figure style, i had two figure style for the same object with different propriety. And applied the wrong style on the figure prefix database.
