surfaces through xref or dS section views and compute materials
I created a new file, data shortcut an alignment and xref'd a file containing a corridor, top corridor surface and datum corridor surface and existing ground surface.
I then created sample lines. I was allowed to choose the surfaces as a sample source. When I created multiple views, the surfaces didn't show on the cross sections. When I computed materials, I was allowed to select the existing ground and datum surface for calculations. I then ran a volume report and it shows 0 for everything.
I then data shortcut my datum surface. I think checked my sample line sources ans was able to add this DS surface to the sample lines. Then the surface showed up in my cross sections.
I am having trouble explaining the deal with xref surfaces and duplicate data shortcut surfaces and why some work and others don't. Is there a workflow documented somewhere on surfaces through xref files? Thanks.
