Civil 3D Forum
Surface Legend Tables - set default styles?
3 REPLIES 3
BMcAnney
530 Views, 3 Replies
Is there a way to set the default style used for each of the Surface Legend Table types (directions, elevations, etc.)? For other objects, such as alignments, I can set the default style in the command settings for that object. But I don't see any command settings relating to surface tables. Civil 3D 2008.
Anyone know?
Thanks!
Brent McAnney
3 REPLIES 3
in reply to: BMcAnney
Brent,
I don't find that ability either. I guess the simple solution is to set the
Standard style to your standards (makes sense, I guess). If you want
something other than the Standard style you may just have to change the
style after creation!
Happy Modeling,
JD
Yes, I found it!!!!
In the Toolpsace->Settings tab, Surface->Table Styles->Elevation, right-click on the currend default style ("Standard") -> "Replace with..."
In the next window you can pick the legend-style you want and make it de default-style
M_c3d
I was looking for this a long time ago, the actual place it is set is within each surface style, rather than doing a find and replace (albeit that would be quicked);
  • Surface Style >
  • Each Surface Style >
  • Summary >
  • Levels >
  • Legend Style
I have a default surface style for cut & fills that is set within the template and the table style is associated to this
Rail Community
