Surface Legend Table Scale Incorrect when Plotting
m_kingdon
Advisor Advisor
m_kingdon
It is always nice when a workflow you have used for many years suddenly stops working.  It prevents complacency.
For my cut and fill drawings, I have always added an additional viewport to display the surface legend table.  Recently however, the scale at which the table is displayed in the drawing and the scale in which the table is plotted is different.  I can’t understand why this has started to happen as I don't believe I have changed anything about this workflow recently.
How the table is displayed in the drawing
Plot Preview.  The table is at a much larger scale and not possible to see.
Mike Kingdon
Civil 3D Zealot
MichaelH13
Oh joy, scales.
Something has changed in the table style?? Something changed with the viewport scale override??
I'll be interested to see what the fix is 😄
Udo_Huebner
I have seen similar issue with Point Tables. But this issue was solved after installing the latest Update Civil 2024.3 from last week.
https://help.autodesk.com/view/CIV3D/2024/ENU/?guid=civil_3d_2024_3_fixed_issues
Gruß Udo Hübner (CAD-Huebner)
m_kingdon
Yes, the new 2024.3 seems to have fixed the problem.
Mike Kingdon
Civil 3D Zealot
cwr001
Glad it works again. In my opinion, the implementation of tables in Civil3d leaves a lot to be desired - but we have to work with what we've got, I guess.
I don't know if you need it, but just as a little tip because it caught my eye immediately:
If you set up your tablestyle like this, you'll get an easily achiveable background masking (it's missing in your screenshots).
