SURFACE EXTENSION
SURFACE EXTENSION
SURFACE EXTENSION
 I have a basic lane 12' for a ramp. There is a point where the width varies .  What sub assembly do I use to extend my corridor over and close the gap. Because it varies like it does I would think a boundary is needed?
wfberry
There are several pavement subassemblies that you can set a "target"  for.  IOW, using a Feature Line, polylines etc.  Some may be used as offset targets as well as an elevation target.
Use the help screen that you select when you modify the subassembly.
Bill
Joe-Bouza
I try to stay clear of "Basic" subassemblies"  at some point you will be hemmed in by them. use the outside lane super or the trapazoid has flexibility
Joe Bouza
