Surface Created from Contour is 1000m below the Contour level
patrickoT4YDR
patrickoT4YDR
Please could any help me understand why my surface created from contours imported into Civil3D as a dxf file is 1000m lower that the level of the contours.
The contour lines are polylines with elevations ranging from 1300 to 1500m, but when I create a surface from the contour lines, the surface is at an elevation that range from 300 to 500m. So the level on the surface corresponding to a contour line of 1300m will be 300m. I tried using MAPCLEAN to clean up the contour polyline first before creating the surface, but the problem persists.
The contour dxf file is attached.
Replies (8)
neilyj666
I'm not seeing an issue here - I INSERTED the dxf into my standard template, built the surface from the contours and surface label shows 1425 and polyline used to build surface also shows 1425
Can you share the dwg with this issue?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2025 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
patrickoT4YDR
Do you mind explaining how you INSERTED the dxf?
I went about it another way, by opening the dxf file and then saving it as a dwg.
patrickoT4YDR
Do you mind explaining how you INSERTED the dxf? I went about it another way, by opening the dxf file and then saving it as a dwg.
neilyj666
I would never recommend this workflow as it usually causes scaling issues etc.; furthermore if you use your standard Civil template you have all the styles etc available
I'm assuming this is a metric drawing, use the command INSERT and select the dxf, basepoint 0,0,0 (if asked)
Pointdump
Hi Patrick,
"...by opening the dxf file and then saving it as a dwg."
That's what I did too, and the surface I created seems OK.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
AllenJessup
There's also the old DXFIN command.
Allen Jessup
CAD Manager - Designer
neilyj666
@AllenJessup yes a oldie but still works also less control compared with INSERT.
More often than not I have to scale dxf/dwg files from third parties as they have been provided in mm
AllenJessup
@neilyj666 Yes. I use the open & save method most of the time. Just happened to remember the command.
I usually don't need to scale or rotate the DXF since most of the ones I deal with I've created from a GDB using QGIS.
Allen Jessup
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
