Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Civil 3D Forum
Surface Contours
19 REPLIES 19
Message 1 of 20
LarryS23
906 Views, 19 Replies
Surface Contours
I am trying to create a surface with presentable counters. Notice in the picture attached how the minor contour just drops off. I have tried deleting lines and add points and not really getting anywhere. The elevations around the top vary note. Also when I tried to weed the feature line the drawing tends to crash. surface triangulation.JPG
Labels (2)
19 REPLIES 19
Message 2 of 20
rl_jackson
in reply to: LarryS23
If the upper portion of you imiage is outside the limits of your survey you should go to the Surface Properties - Definition Tab and set the Use maximum triangle length to Yes and set a comfortable length based on your data spacing. I usually start with 100 and work from there. If your issue is the pull that is happening then I might consider deleting that point from the surface using the Surface Edits with the points and triangles on.
Rick Jackson
Survey CAD Technician VI
Message 3 of 20
Joe-Bouza
looks like a bust in elevation from here. is this topo or FG?
Joe Bouza
Message 4 of 20
LarryS23
in reply to: Joe-Bouza
Supposed to FG. The FL elevations vary from 5 to -2. So this might be causing the issue? Not entirely sure
Message 5 of 20
Joe-Bouza
the elevation values would not matter it where they are and how they relate to the others. I can see where I circle something is getting fouled up.
possible culprit another feature line under the design that is in the same site. Lets see the elevation editor of the toe..
can you post the file?
Joe Bouza
Message 6 of 20
LarryS23
Could be...I’ll check in the morning about the FL suggestion. Will post the file if that doesn’t solve the issue
Message 7 of 20
LarryS23
I attached the layout of the pond. I used grading creation tools and a stepped offset to create this layout. Working on trying to create the surface from this but am running into difficulties as I said before with the contours.
Tags (1)
Message 8 of 20
Joe-Bouza
Hi Larry @LarryS23  the file has some corruption and will not open on my end.
Run recover/ audit purge on your end and repost if possible
Joe Bouza
Message 9 of 20
LarryS23
I attached the dwg. I added some low spots to fix the bottom of the pond contours. The outside contours near the top still do not look as presentable as I want.
Message 10 of 20
Joe-Bouza
you have something weird going on with your feature line for top of slope
Triangle are PVI circle are elevation point. Green triangles and circles are shared point with other feature lines in the same site. white triangle mean another feature line is crossing . I cannot find these shared feature line points or crossing. did you create the top of slope FL from drawing objects? if yes there may have been overlapping geometry that is internally  effecting the feature line
https://knowledge.autodesk.com/support/civil-3d/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/Civi...
Joe Bouza
Message 11 of 20
LarryS23
I created the top of the FL using the stepped offset command.
Message 12 of 20
Joe-Bouza
Move it to a different site and you will see the split points and shared point marks go away. this has to be effecting the pond.
The stepped offset was from the Grading FL? That should yields a clean FL with no effects from other FL.. This is puzzling
Joe Bouza
Message 13 of 20
Joe-Bouza
Whhat is the top of the grading based on? there are many irregularly space elevation points. Is this line starting at EG?
Joe Bouza
Message 14 of 20
LarryS23
The middle FL is the one that started at EG.
Message 15 of 20
Joe-Bouza
thats  what I figured. I cant put my finger on anything other then the shared and split points in the top of slope feature line.
part of wants to blame the geometry ( please take no offense  ) When I see grading projection at inside corner overlap I get worried. I try to get my geometry curved in these area that would project to a smooth inside radius. Also I try to  minimize the elevation points. for instance in the lower left of the pond the elevation points are very clustered together . I try to normalize the  elevations so the grading isn't make so many different slope projections so close together.
I thing the geometry of this feature line is collapsing on it self when projected and stepped offset.
Joe Bouza
Message 16 of 20
LarryS23
Yeah that's what I am thinking too in regards to the geometry
Message 17 of 20
Joe-Bouza
you are a little short of EG on the east side
I did a redo geometry of the feature lines  and things look pretty good except the tie to existing on the east side
Joe Bouza
Message 18 of 20
Joe-Bouza
I guessed what the river bank elevation is and extended EG . now the grading is complete
Joe Bouza
Message 19 of 20
LarryS23
Thank you. I noticed that too in regards to the pond being outside the EG. I changed the top of my pond to elevation +1 all around because that’s what the design I found out today is instead of taking the top of the pond at the EG elevation. Had to change some contours and add some points but it was much easier to work with because the geometry of the FLs were not so complex. Will look at your drawing. Again thank you all for the help
Message 20 of 20
Joe-Bouza
HTH
Joe Bouza
Rail Community
