Surface Area Limitations for Printing Dot Hatch
Just encountered an issue with printing dot hatch.
Turns out if the surface area of the dot hatch is greater than 180,000 sqft the hatch will not print. If you change the hatch pattern to any other pattern it will print.
Has anyone else encountered this issue? and is there a fix?
Thank you,
hugha
Try entering EXACTLY the following at the command prompt:
(setenv "MaxHatch" "1000000")
hth
