Hello engineers, I've modeled an alignment that has 4 compound curves in some sections with different radius, I did this because I wanted to avoid unnecessary straights in areas that just want long curves, my aim is to try and get civil 3d to give me super-elevation for these 4 compound curves as just one big curve to ensure I get good transition crossfalls from straights into these 4 compound curves and then back again into straight, is there a way I can edit the super-elevation to make civil 3d treat these four curves as just one curve or how can I get just normal smooth transitions cross falls just the same way I would when moving from starting and into a simple curve then back into a straight, thanks
