Subdivision Grading Plan - Pad on lots
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Normally my plans for a subdivision do not extend beyond the right of way line, however, I have a client who likes an incorporated lot grading on his plans. What I have done to date is grade a corridor surface, then use feature lines to raise the front lot line 2 feet to the MBL, then offset that line to create a front to back level area. The side to side slope is a result of the road grade and the aforementioned feature lines. The client wants us to grade each lot with a "pad" for the home/yard area. Basically a flat rectangle within the lot limits as per the attached JPG. My thoughts are to create another feature line on top of the lot with each corner set to level. My results were mixed with some contours becoming confusing looking. Is there a better way of doing this?
Thank you for your time.
