Subassembly to daylight sloping up away from the alignment
Ross_S1
Ross_S1
I am trying to create an assembly to daylight sloping upwards away from an alignment. I tried the DaylightMultiIntercept subassembly, but this didn't seem to let me slope upwards in a fill slope. What might be an option here? Attached shows what I am trying to model and where I am with results.
Thanks in advance for your input and time.
ecfernandez
I could not understand easily what the final result should look like. Could you please post a screenshot of what you are getting in the cross sections, instead of your assembly?
Camilo Fernández
Civil engineer | Specialist in design, construction, and maintenance of roadways
LinkedIn
Ross_S1
I did not generate a corridor with that Assembly. I didn't think it was functional, the way it looked. Hence I don't have a cross section to show you. I put a new image attached trying to show you what I am after. Link slope to surface achieves what I was trying to do here. I'd still be interested in seeing if there's a way we can use the DaylightMultiIntercept subassembly, as it could have made a more useful result.
