Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Hi aramia436,
Sometimes if corridor section not follow sample lines chainage, in section view missing some lines. As option try to add corridor section on each sample lines as you can see on attached pictures.
Hope this help
Hi aramia436
I know this problem can be very frustrating, but it can always be solved in some way. If you put corridor section over each sample line and issue are still appear try to do following. Move a little each sample line as you can see on attached video.
Hope this can help you.
I made another sub-assembly All sections were correct and there was no need to move the sample line and I set the corridor frequency to 100 Now the problem is from the 0+000 section and Should not use slope to surface
