Civil 3D Forum
Subassembly slope to surface not work
5 REPLIES 5
Ramin-AZ
682 Views, 5 Replies
Why the link does not connect to the surface
5 REPLIES 5
M_Obradovic
in reply to: Ramin-AZ
Hi aramia436,
Sometimes if corridor section not follow sample lines chainage, in section view missing some lines. As option try to add corridor section on each sample lines as you can see on attached pictures.
Hope this help
Ramin-AZ
in reply to: M_Obradovic
thx for answer,I added chainage of section to the corridor, but it didn't work
jroot
It looks like there are no subassemblies that target a surface.  Either that or the target surface was not defined.
M_Obradovic
Hi aramia436
I know this problem can be very frustrating, but it can always be solved in some way. If you put corridor section over each sample line and issue are still appear try to do following. Move a little each sample line as you can see on attached video.
Hope this can help you.
Ramin-AZ
I made another sub-assembly All sections were correct and there was no need to move the sample line and I set the corridor frequency to 100 Now the problem is from the 0+000 section and Should not use slope to surface
Rail Community
