Subassembly conditional
Mouhamadkh
Message 1 of 9
Mouhamadkh
HI
In my assembly there is two types of curbs, one is dropped which is between asphalt and parking area, the other is up stand up which it between parking and footpath area.
Is there any condition in SAC can assign to the sub-assembly in case if no parking in the corridor it should be only apply the up-stand curb with all layers and details .
Here in below I attached a file shown the Subassembly and curbs types .
Replies (8)
Message 2 of 9
wfberry
I believe that a CONDITIONAL HORIZONTAL SUBASSEMBLY should work for you.
Here is an example of how it works:
https://www.youtube.com/watch?v=4xam6QfzcAc
Bill
Message 3 of 9
you could make a decision in SAC using offset target and condition for decision using api target.isvalid, and then you define geometry for your two curbs.
Message 4 of 9
lynn_zhang
Hello @Mouhamadkh , thanks for posting!
Just checking to see if your problem has been solved. Have you tried the suggestions above and did any of them work? If yes, please click on the "Accept as Solution" button in their reply so this helps other users in the community find the solution too. Thanks!
Lynn Zhang
Message 5 of 9
Mouhamadkh
Hi @lynn_zhang  ,
Not solved , the materials is overlapping ,cause of target .
sorry for delay , i was outside of office .
Message 6 of 9
Mouhamadkh
HI @lynn_zhang
sorry for delaying , i was outside of office .
Message 7 of 9
lynn_zhang
Hi @Mouhamadkh Sorry to hear it was not solved!
@wfberry @Anonymous Could you take another look at the problem?
Lynn Zhang
Message 8 of 9
M_Obradovic
Hi.
In SAC there is a way to do it. You can use offset target and give name (Parking). Than create auxiliary point with slope and deltaX and apply offset target. Make decision as Parking.IsValid and True side you will have both curb and on False side you will have just upper Curb.
If you have PKT file you can post here.
Chears Milos
Message 9 of 9
Joe-Bouza
can you post a file ofr screen  shot. I dont understande "materials overlap"
the OOTB conditional sub is very powerfull and can handle many layers of if else
Joe Bouza
