Hi everyone,
(copied/moved from Customization)
Base on the picture attached...
For Fill conditions, I am looking for a way of Varying the Slope to the Ditch Bottom(given from profile), starting from the Daylight point from the EG, going in Cut.
Picture: When I have Ali for the Ditch (target found) I have SlopeToElevation №1 circle going in 1:3 slope to the Profile for the DitchBottom.
Now - If this vertical distance between EG and DitchBottom is greater than 0.5m, I want the Slope To the SAME DitchBottom to be 1:2 №3, if less than 0.5m to be 1:3 №2. It finishes both with 1:10 or with 1:6, if greater than 0.5m in cut, to the EG Surface, as in the typical profile case, drawn down left side ....
I really struggled with it, trying Links with NoDisplay styles, or more logical 1st time - Omit Link option, but unfortunately it can not Insert either №2 or №3 SlopeToElevation subassembly on the starting point of the 1st one №1, and this is what i want.
Basically - Based on Depth, insert both A or B, without inserting smth to check the Depth.
Greetings!
