Subassembly Composer – Shape for Loop Geometry
Is it possible to generate the Shape "Triangle" for the portion of Loop Geometry?
KMercier_C3D
Not using loop geometry, unfortunately, but you could do it the more manual way by setting up a series of Decisions to check if the next links and shapes should be generated or if your next point would be below the surface. You would need to decide how many maximum 'loops' you would want to check and need to set up that many decisions. A bit painful but it should get you the end result you are looking for.
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
Hi KMercier,
Thank you for your recommendation and I had also made reference to your previous reply (the BlockWall.zip)
https://forums.autodesk.com/t5/civil-3d-forum/sac-marked-points/td-p/3188240
Agreed that number of “Decision” should be added for creating the Shape. In actual, the total number of Shape was affected by the Height of Fill [L2], Slope Surface [AL3] and Inclination [AL4]. The pkt revised and worked fine!
Right now, in C3D, error “Object reference not set to an instance of an object” appeared for several chainage if 0.05m was input for Height L2, but free of error for Height larger than 0.05m. How could I solve this issue?
KMercier_C3D
Have you been able to recreate this error with changing the surface elevation in SAC? It is difficult to trouble shoot why this may be happening without seeing the .pkt file (.zip to attach). My guess is that there may be a hole in one of your decisions that is causing it to not know what to do.
Pronouns: She/Her
