Subassembly Composer reverse engineer stock subassemblys AKA look at
PeterKozub
PeterKozub
Hi
Is it possible to bring a stock C3D assembly into sub assembly composer to see how its built
TIA
KMercier_C3D
The stock subassemblies were built using a different methodology than subassembly composer so they can't be directly opened in SAC.
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
MikeEvansUK
Some are directly available in the 2016 Propack 3 (C:\ProgramData\Autodesk\C3D 2016\enu\ProPack 3 Subassemblies)
But I believe the stock files are available in their raw code format (C:\Program Files\Autodesk\AutoCAD 2016\C3D\Sample\Civil 3D API\C3DStockSubassemblies)
These are viewable with vb express but you need to know programming to understand them.
Mike
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
