Subassembly Composer loop problem
c_teymurxanov
c_teymurxanov
Hi everyone. There is one problem which I can solve myself, need your help. When I move yellow surface in right side of image as you see every time error appears. What is reason of this. What I can do to solve this issue. I attached screen and pkt file. Thank you for your attention. Loop geometry error .jpg
KMercier_C3D
I was not able to recreate your issue with that pkt file by changing the TZ surface value using the default values for all of the input parameters.
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
I get a similar error every time I try to do a similar thing with loop geometry. Now that you mention it, it always happens when moving the target surface preview line. I tried on a colleague's computer and didn't get the same result, so I'm thinking it's a bad installation.
Did you ever come to the bottom of it?
Strator
I have the same problem, but I resolved it. The function does not work on 2021 but the same file is working on 2020 version.
consultora
I Have the same problem, using SC 2024
