Subassembly Composer -- How to ask if a point exists
tcorey
Mentor Mentor
tcorey
Using Subassembly Composer, we want to test for daylight. If daylight is not found, out Auxiliary Point will not be created. How do we code a decision that says "If AP1 does not exist...?"
TIA,
Tim
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
doni49
AP1.IsValid()
http://knowledge.autodesk.com/support/autocad-civil-3d/learn-explore/caas/CloudHelp/cloudhelp/2014/E...
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
tcorey
Thanks, Don!
Tim Corey
Redding, CA
4thespirit
I know how to use the "ISVALID" but my question is how do I simulate that point being invalid while still in SAC so I can see how my subassembly will behave when that is true (the point does not exist)?
joantopo
@4thespirit
You can disable a target (checkbox). In this case, daylight, you can disable the surface target in SAC and your scenario will be in "IsValid=False".
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
