Subassembly and Multi Surface
neam
Message 1 of 25
neam
How to define a sub-assembly such as an attachment to produce a corridor in two different surfaces?
Thank you for your guidance.
Replies (24)
Message 21 of 25
neam
Thanks a lot milos
I will check and I will definitely inform you.
Message 22 of 25
neam
Hi milos
i check your pkt file but But unfortunately the same initial problem occurred and the sub-assembly is not inserted correctly
Message 23 of 25
M_Obradovic
I create in SAC 2021 and from this reason appear this issue. Try to open in 2019 as i suggest before and save as with different file name and also different subassembly name. This should solve issue.
Message 24 of 25
neam
thank you very much milos
every things is okey😀😊
Message 25 of 25
bpatelk
n C3D , in subassembly, we want to give detail of subbase, datum, pave , top , how can I
Dr. B K Patel
