So I used the out-of -box-box crowned lane sub-assembly (Civil 3D 2022) for a number of locations along my 10 km corridor and in each instance, the top grade is 0% even though each sub-assembly shows the desired 2% grade. I've checked that I am using the correct sub-assembly in each instance, I've changed the display style, shut down and restarted Civil 3D and rebuilt the sub-assembly and it always goes back to 0%. It does, however, appear honour the sub-base grade of 3% (I've included some screen shots below).
When I use other sub-assemblies in the same corridor region with a top slope of 2%, such as the BasicLane sub-assembly, it displays as it should in the section view. Has anyone else experienced this or have a solution? I understand that I can build the sub-assembly layer by layer, but I would really like to use the pre-defined crowned lane sub-assembly for time savings and ease.
