Sub Assembly Composer Help
jsorrells
jsorrells
I am new with assemblies and corridors, so I hope someone can help me out here.
What sub-assembly do I use to achieve going through the existing ground twice at a 17.5:1 slope.
Image attached will probably explain my problem. Thanks!
schroederC3D
You're looking for the DaylightMultiIntercept assembly - check it out in the subassembly reference, and set the Intercept Number to 2.
If this solves your issue or answers your question then please hit the KUDO button or mark as an ACCEPTED SOLUTION!
Reply Syntax?
Command (Uppercase): TRIM, Variable (Italicized): MSLTSCALE, Civil 3D Object (Within brackets): [SITE]
Please support my Idea to revert the forum format to the old one: https://forums.autodesk.com/t5/community-ideas/revert-to-old-forum-layout/idi-p/7917987
KMercier_C3D
Try DaylightMultiIntercept
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
jsorrells
DaylightMultiIntercept assembly worked, had to add the target surface in the properties!
