Structure Label Pipe Reference
I am trying to create a structure label that references the the outflow pipe size and 1 inflow pipe size.
Example:
Install 24"x18" Wye.
I can live with:
Install 24"x18"x18" Wye.
But when I use the Text for Each, it puts the 2nd inflow pipe on another line.  I am trying to not create 100's of separate label styles.
Thanks in advance
Sean Faulkner, PE
JustOpie
AFAIK, there is no option to have the Text for Each add text on one line only.
troma
Would be nice to have labels like this.
For now, I think your options are either create a default label and edit the label text every time you place it, or just use text or a Mleader.
Mark Green
Working on Civil 3D in Canada
doni49
Welcome to the forum.
I'm sorry to say that the best idea I can come up with is to use the DESCRIPTION field (of the structures) and then make 1 label style that uses the description.  I've attached the dwg file from the image as an example for you.
C3D does have shortcomings and IMHO this is one of them.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
