Civil 3D Forum
Structural Properties
4 REPLIES 4
climMKY8F
222 Views, 4 Replies
Hello experts!
I have created an existing sewer line and will need to adjust the settings on some of the structures within the structure properties. And I noticed that some structures does not have the "Insert Rim Behavior" or "Sump Behavior" (see image attached). How do I fix the structures that does not have these options since these are the two settings I will need to change? And why do these structures not have those options either?
Thanks in advance!
4 REPLIES 4
MMcCall402
in reply to: climMKY8F
"Null Structures" don't have rims or sumps.   They're basically a pipe to pipe connection.
Mark Mccall
CAD Mangler
Hammer Land Engineering
Linkedin
climMKY8F
in reply to: MMcCall402
Hi Mark,
Thanks for that information; how does one change the structure so that it does not become a "Null Structure" without deleting the structure or existing sewer pipe lines I have already created?
Thanks!
MMcCall402
Select the null structure and 'swap' it for a type that has a rim and sump, like a manhole.
Select it and choose "Swap part..." from the right click menu.
Mark Mccall
CAD Mangler
Linkedin
climMKY8F
Thanks for your replies Mark - they both helped me!
Rail Community
