I have not been able to find a way to straighten a curved section of a feature line or to add a straight section in the middle of a curved FL. I am aware of the EDITFEATURECURVE>Delete option, but that removes the whole curve instead of making it straight. I am aware of the SmoothFeature>Straighten option, but that straightens the entire FL and not just the curve in question. I can add PIs to the FL but the new sections of the FL are curved. The geometry of my parking lot changed from the green FL to the while PLine, and I can't figure out a way to make the change without starting over on a lot of things. A grading infill was used and the FL has grading objects attached, so breaking it is not an option without redoing all the grading objects. A workaround that will help me edit this particular feature line would be marginally helpful, but I'm really looking for a way to straighten curves which I'm not thinking exists. I'm thinking like PLine grip edits, convert to line, or an equivalent command. This problem has popped up several times and I'm in need of a solution.
