Storm and Sanitary Sewer Analysis - Water Not Finding Its Level
Message 1 of 9
Hi Everybody,
I'm trying to model a detention system in SSA because the evil plan checkers want a few hydrographs. It's a simple system, a 48" detention pipe flows into a drain box with an orifice but I can't seem to get it to model right. As shown in the picture below the drain box fills up and overflows but the 48" pipe is only filled to a depth of 2". Any idea why the 48" pipe is not filling up as the storage box is?
Thanks for your help,
Dan K
Replies (8)
Message 2 of 9
wfberry
Dan I wish I could help you but ever since Chris Meador left Autodesk several years ago SSA is like a ship with no Captain.  It is really sad.
Bill
Message 3 of 9
wfberry
Message 4 of 9
BrianHailey
Can you share your model? I'll take a look at it and see what I can find.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 5 of 9
Here you go Brian. There's also a PDF of a detail of the detention system. I combined a couple pipe volumes into one big 48" pipe to make life easier on myself in SSA.
https://www.dropbox.com/sh/ko8u1mhc32d52qz/AAAIwW4VQ8FQFafsjT5GlUova?dl=0
It's not totally correct but when I've modeled the system with one giant storage vault with the total volume in my system I get results that might be close enough to the real thing that no one will notice.
Since SSA is pretty much unsupported these days does anyone know of a good program to do analysis like this?
Message 6 of 9
Hidden_Brain
i did not open your model, two questions:
1. are you loading the influent drainage area to the drain box or to the node upstream of the 48"?
2. goes along with #1 above, are you running hydrodynamic? (Input>Project options>link routing method)
Message 7 of 9
BrianHailey
You have the analysis type set to "Kinematic Wave". This doesn't allow reverse flow in a pipe (you can think of the wave propagating along the pipe). If you change that to "Hydrodynamic", you'll get the results you want.
2018-08-03_1318
GEI Consultants
My Civil 3D Blog
Message 8 of 9
I knew there was some checkbox somewhere that I was missing. Thank's a million Brian!
Message 9 of 9
As these things go the solution created another problem. When I had this set up for no reverse flow, basically with no detention, I had minimal overflow, 0.02 acre-in for 8 min.  Now that my 48" pipe is being used to store water I have a flooded volume of 417.6 ac-in for 202 minutes. This doesn't seem right. Is there another magic box I need to check?
