Stitch together GEOMAP Bing imagery spanning coordinate systems?
akstrum
Message 1 of 8
akstrum
I'm working in C3D 2015 on a >300-mile pipeline project which spans from one coordinate system into the next. I need to stitch together GEOMAP captures for a key map sheet.
The Bing imagery looks great in both coordinate systems. I can't figure out how to re-project or reference or query one coordinate system's GEOMAP image into the other coordinate system's dwg file is such a way that the imagery appears contiguous.
Ideas?
Replies (7)
Message 2 of 8
You can use raster design if you have it available to you.... check out the following threads
https://forums.autodesk.com/t5/autocad-raster-design-general/merge-images/td-p/1773514
https://www.youtube.com/watch?v=dx7hw4VzQxs
Hope that helps
kudos are always welcome
Message 3 of 8
akstrum
Thanks for the response.
I do have raster design, so that's a plus.
What I've not been able to do is place GEOMAP image captures from two different coordinate systems side by side in a dwg in order to perform an image merge. The image capture itself updates when I change the coordinate system of a drawing . . . so how can I capture two coordinate systems in one drawing?
I think what I need is a raster export with world file from CoordinateSystemA.dwg which I could MAPIINSERT into CoordinateSystemB.dwg. I have not been able to generate a world file for a GEOMAP image . . . and--beyond that--I'm not sure how the world file would place the raster in a different coordinate system. Of course, I could ALIGN the imported image and bully it into place . . .
Message 4 of 8
This might be helpful...it discusses how to create a world file manually
http://www.cadtutor.net/forum/showthread.php?62013-export-a-clipped-georeferenced-image
Unless you have GIS there's no 'easy' workaround that I'm aware of.....
As an alternate suggestion, there should be free geo-referenced images available through USGS or other agencies (if you're in the USA) that may have a continuous geo-referenced image
Hmmmm...
Message 5 of 8
Pointdump
J,
You could create a custom map projection that includes the entire project: Transverse Mercator for north-south, Lambert for east-west, or Oblique for any other direction. Drawings from both coordinate systems can easily be brought into the new coordinate system.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 6 of 8
antoniovinci
I fear you won't achieve your goal in a Cad environment, sir.
You need some Gis software, e.g. the free Qgis.
Message 7 of 8
Pointdump
J,
Another possibility, from the Apps Store:
https://apps.autodesk.com/CIV3D/en/Detail/Index?id=appstore.exchange.autodesk.com%3aplexearth3%3aen
Dave
Dave Stoll
Las Vegas, Nevada
Message 8 of 8
akstrum
Excellent! I created a custom coordinate system from an existing coordinate system, and extended the westerly longitude parameter to suit my needs. The GEOMAP image then covered the two standard coordinate systems; the BING imagery slipped right into place.
The solution (thanks PD!) is very quick and easy.
Thanks a million for the crew's many responses and ideas!
