Let's imagine that your alignment is more than a mile long. But because of the scale of your sheets, you can only show a few hundred feet at a time. In the attached dwg file, I created an alignment that is much longer than a mile.
Then I've got one long Profile View showing the entire Profile. Then I copied that profile view down below it. I changed this new PV's properties so that it ends at station 3+50.00. Then I copied that one and changed it so that it begins at 3+50.00 and ends at 6+00.00. Lastly, I copied it again and changed it so it begins at 6+00.00 and ends at 9+50.00. These are the PVs that I'd show in my viewport on the sheet. If you make a change to the main profile (the top one, that change will automatically follow through on the smaller PVs.
Go ahead and try changing the profile -- grip edit the beginning and raise it up higher. You'll see the change in the smaller PVs.
EDIT: here's a screenshot for you.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
