The images below show where to find the label settings for the geometry points (PC, PT etc). The other station labels will be done with the the same methods but using a different label style.
EDIT: As Jeff said, if you use a METRIC template, these settings will already be configured for you. And there area a myriad of other settings that need to be dealt with if you're working with metric. So even though you CAN go through and change the settings, I'd advise you to bite the bullet and use a metric template.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
