SSM - Sheet Views Tab - Display, strange behavior
Hello all,
Every time I use the Display option of a View in my Sheet Views tab the following happens. Clearly, the viewport being locked initiates the problem and results in "_restore" being issued as a command rather than a "_.-view" command option in the prescribed "Display" actions. It seems a bit short sighted to not anticipate that a viewport could be locked and have the Display function respond accordingly.
I was in a separate drawing than the Sheet Views when this happens. Also, I am working in SDI=1 (only one drawing can be open at a time). It opens the drawing with the view just fine. It has this problem when the viewport is locked.
Command:
Opening an AutoCAD 2018 format file.
Resolve Xref "SoPi-22.01-g01tbx01": .\SoPi-22.01-g01tbx01.dwg
Resolve Xref "BBW_PE": BBW_PE.dwg
Resolve Xref "Pavement And Curb Patch Details": .\810 Design Drawings\Details\Pavement And Curb Patch Details.dwg
Regenerating layout.
Regenerating model.
Command: nil
Command: _.-view
Command unavailable in view-locked viewport.
Command: _restore
RESTORECORRIDORBOWTIE
Select a corridor: Sidewalk
*Invalid selection*
Expects a point or Last
Select a corridor: Replacement
*Invalid selection*
Select a corridor: 2
Nothing selected.
Select a corridor:Every time I use the Display option of a view in My Sheet Views Tab I get the following behavior
Authorized Autodesk Developer
Civil Design Specialist – Water & Wastewater Infrastructure
