I am modeling an overflow discharge network from a large detention pond. The peak 100 year flow from the pond is 7.45 CFS, which I have added as an external inflow to a junction leaving the pond. This is just a test so I do not need to model the actual discharge structure from the pond.
When I run the model using Hydrodynamic method the peak flow in the pipe immediately downstream of this junction is much higher, peaking at 10.06 CFS during the first few minutes of the analysis.
This is clearly incorrect as the only flow entering this pipe is the constant external inflow of 7.45 CFS. This can be confirmed by creating a time series of the total inflow to the junction.
If I change the analysis method to Kinematic Wave or Steady State the flow in the pipe is calculated correctly as a constant 7.45 CFS:
Why does using Hydrodynamic method cause such an error in the maximum flow in the pipe?
