SSA display options
SSA display options
terry_laird
SSA display options
terry_laird
New to using SSA, when I run the model the pipes that are in surcharge turns red. Pipes that are at capacity do not change colors or anything to tell you they are at capacity is there a way to change this?
brian.strandberg
There is a setting in Display Options (View / Display Options) to turn this on/off.
Let me know if this answered your question, I'm not too familiar with SSA but I have had this question before.  Thanks.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
terry_laird
Thank you Brian that is how I have it set but it does not change anything on the pipes at capacity.
MattAndersonGauge
Best to turn on Links > Proportional to value, and Set Link View to Max Depth
