Spot Elevation Comparison Grid from -/+ to C/F
rjames94
rjames94
Is there anyway to change the spot elevation grid labels to use C (Cut) and F (Fill) instead of default positive and negative signs? I looked into the label settings and don't see a option for that or know of a way to customize it to get what I need. Let me know if there's any solution to this, thanks!
Accepted solutions (3)
Replies (8)
could you write an expression to do it? I don't have it open right now, can't check.
rjames94
I'm not very familiar with expressions. After some researching I found a way to color the text red/blue depending on if its a cut/fill. Still would like to add the C to all cuts and F to all fills.
rl_jackson
Could this be something that u could use Earthwork Plan Production on. It sets up a grid surface and provides all this information based on your defined grid size. I use it to calculate the amount of fill in a mound based on the 2 surfaces....
Maybe a image of what your working with would help.
Rick Jackson
Survey CAD Technician VI
ChrisRS
I would use the expressions and the 'text height trick'
3 expressions: *
Label Text Height:   0.125/12        This is the desired text height in feet
Cut Text Height:      IF({Surface Elevation}>=0,{Label Text Height},0)        Text Height if in Cut, 0 if in Fill
Fill Text Height:       IF({Surface Elevation}>=0,{Label Text Height},0)        Text Height if in Fill, 0 if in Cut
The Label will require 3 components:
Cut Fill components.pngConceptually, each label will read C:F:xx.xx, with either teh C: or F: text height set to 0 making the invisible.
Please note the Text height, Anchor Point and Attachment settings for each component.
Also note that the sign is dropped for the Surface Elevation component.
* Strictly speaking, 'Label Text Height' expression is not needed. It is used as a constant that makes the other expressions more readable. Should you wish to chanfe this text height, it only needs to adjusted in one place.
Good luck.
Christopher Stevens
rjames94
Still facing a few issues after applying your settings. Looking to use the spot elevations on grid to achieve what you show. Below is what I'm getting, also posted my settings. Am I missing something? Let me know, thanks.
x0Ub0OoHGf.gifacad_ziLSFA7DiE.pngacad_lQKYVJzRUY.pngacad_m6sT4bw8X0.pngacad_ZAHBdQp7UB.pngacad_h7NfUc5hrz.pngacad_YFjpULxd3m.png
ChrisRS
  1. Sorry, there is an embarrassing typo in my original post.
    Cut Text Height should be "<", not ">=+":
          IF({Surface Elevation}<0,{Label Text Height},0)        Text Height if in Cut, 0 if in Fill
  2. Fill Component (also my typo):
    General: Anchor Point: Middle right
    Text: Alignment: Middle left
I will post a correction.
Good Luck.
Christopher Stevens
rjames94
Works beautifully. Thank you very much
ChrisRS
This is a correction to Post 5 an discussed in Post 7
3 expressions: *
Cut Text Height:      IF({Surface Elevation}<0,{Label Text Height},0)          Text Height if in Cut, 0 if in Fill
* Strictly speaking, 'Label Text Height' expression is not needed. It is used as a constant that makes the other expressions more readable. Should you wish to change this text height, it only needs to adjusted in one place.
Good luck.
Christopher Stevens
