Splitting up large projects for design efficiency
I am working and it long pipeline project that includes multiple pipe in conduit alignment many Crossing services in significant Earthworks. The project is about 8 km long and covers 50 m width. I have had problems creating the surfaces over such a large area.
It dawned on me that I should split the project up into a couple of sections for calculation efficiency. I know other civil design programs we use we adopt a limit to 4 to 5 kilometres per section.
Is there any guidance on spitting up large projects in Civil 3D in particular given consideration of the following:
1. Surfaces using a combination of Lidar points for the background and regular survey for the detailed areas. I have stripped the Lidar data points to one per metre in an attempt to improve performance.
2. Corridors that need to differentiate out up to 5 different material types and trench volumes for a pipe and conduit runs.
From the design I would like to generate usual deliverables including plans, profile and cross section and quantities.
schroederC3D
I can't offer direction regarding how to split based on length of pipe - but it's more a combination of how many concurrent users, filesize, drefs/xrefs, surface sizes, etc.
I'd suggest looking over the Civil3D Best Practices section of the help for some direction - although how it applies to your particular project will be different.  Once you have a vision for how to manage the data, come bounce it off us and we'll be able to advise a little better on any issues you might run into.
Reply Syntax?
Command (Uppercase): TRIM, Variable (Italicized): MSLTSCALE, Civil 3D Object (Within brackets): [SITE]
If this solves your issue or answers your question then please hit the KUDO button or mark as an ACCEPTED SOLUTION!
Please support my Idea to revert the forum format to the old one: https://forums.autodesk.com/t5/community-ideas/revert-to-old-forum-layout/idi-p/7917987
