Civil 3D Forum
Splitting Profile Views Axis won't display properly
3 REPLIES 3
cpdalton
314 Views, 3 Replies
I made a split profile view and changed the styles for each to disply the axies on the outside edge, but the right axis  for the right profile view only allows the major elevations half way up the axis and then stops (see the attached picture). The left axis shows up properly, and I do not see any difference in styles or anyting else that would restrict the axis annotation from continuing all of the way up. The minor label axis shows up fine.
3 REPLIES 3
AlmasSuljevic
in reply to: cpdalton
Hi cpdalton,
I have not seen that issue myself but would liek to be able to take a look at your drawing. Would you be able to post your drawing also.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Please click on "Accept as Solution" if post helped you resolve the issue.
cpdalton
in reply to: AlmasSuljevic
Here it is. The "Sites" tab is were the sheet is.  I'm not sure if there will be any problems with the xrefs/data refs, though. Thanks!
AlmasSuljevic
I found that only some styles get stuck showing these elevations in the split profile. Intermediate View or Top Stacked View show up OK. Also tried with tutorial drawing by creating split profile it works there too. So it seems that there is something with those styles.
Almas Suljevic
Rail Community
