Split Profile Problem
Alas_1234
Alas_1234
I'm having troubles with split profile  .I have an extreme change in elevation on a Profile, so I split the profile .with 13 m.  I have surface and 1 m below  offset there is cutting surface   . I have pipe system tangent to cutting surface but when I splitting profile some part of the pipe stay under the profile at the bottom and not appear .
I try to change datum but this time free surface doesnt appear at the top.
I attached a picture and cad filefoto2.png  so you can see what I'm talking about.
MMcCall402
Edit the profile view properties to set the appropriate profile to use for determining the split locations and then allow it to set those locations automatically.
#1
#2
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
Alas_1234
Thanks for your answer. I set profile change properties to see pipe profile . it works but this time I cant see surface profile as you can see from picture. I want to see both pipe(red line) and surface profile(blue line) in the single profile view
Alas_1234
Still looking for..
