Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Spinning blue wheel cursor...
Jerry_Barnes
Message 1 of 26
Jerry_Barnes
Recently my C3D 2016 cursor has started to flash back and forth between the normal crosshairs and the spinning blue wheel indicating it's busy, even though no commands are active; it never stops this annoying action. Additionally, if I make some changes in corridor parameters, the cursor blows up and becomes an almost nonstop blue wheel. (There are no lag or delay issues.)
I read a post where changing the Toolspace Settings to "Master View" solves this problem, but I always keep it in Master View, so that didn't help.
Anyone else experiencing this?
Replies (25)
Message 21 of 26
Andrew_Werder
Community Visitor
Community Visitor
This worked for me too. You can toggle view in the drop down at the top of the  Toolspace menu in the Prospector tab.
Message 22 of 26
vaughan.giles7AGEV
I can't believe this actually worked!
Message 23 of 26
pdejesusV5NV8
This worked for me while using version 2022.
Message 24 of 26
lim.wendy
Hi Jerry,
It sounds like this issue could be caused by outdated graphics card drivers or a corrupt AutoCAD profile specific to your environment. Here are a couple of things to try:
  • Update your graphics card drivers- Link
  • Turn off hardware acceleration in Civil 3D- Link
  • Create a new local administrator Windows user profile, log in, and try again- Link
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Message 25 of 26
rilesblomenkamp
This was my fix. Had to be in prospector tab of toolspace to change to master view.
Message 26 of 26
bcookJKFDP
It seems these same symptoms may occur when opening a *.DWG that is stored in a synced folder from SharePoint/OneDrive, and has a file path that exceeds Microsoft's character limit.
The solution, in this case, is simply to reduce the length of the file path. This is done either by renaming the file, or it's containing folder(s), to be shorter.
