Some pipes in profile view show gaps while others don't
JDB423
JDB423
I have an alignment and profile view set up with a pipe run shown on it, there are null structures along this pipe run which I have set to not display in profile view by editing the structure style. Some of the null structures display a gap between the connected pipes while others don't, they are all exactly the same null structure and all have pipes connected either side of them. I've included a screenshot below showing my issue.
Does anyone know why this might be? I have tried a few methods to fix it like switching the structure style or swapping parts but none of them seem to work.
ianjchap
Hi @JDB423,
I generally delete my Null Structures because I don't find them that useful once my Network is in place. This would solve your problem. However, it would be good to know whats causing the issue.
I suspect the ones showing against the ones that don't may be because of the angle of the connection. Try unselecting the Null Structures in Profile view.
Ian Chapman
If you found this post useful, please Like the post.
If this post helped you successfully solve your problem, then click on the ACCEPT SOLUTION button.
JDB423
Thanks for the reply, I hadn't tried removing the structures using the profile view properties, just done that now and it worked!
