Civil 3D Forum
Snapshot
4 REPLIES 4
2735 Views, 4 Replies
Snapshot
If you right click on a surface name there is the option for create a
snapshot. What is it and why would I want to use it?
David Urban, P.E.
Project Engineer
Pape-Dawson Engineers, Inc.
7800 Shoal Creek Blvd. Suite 253 East
Austin, TX 78757
ph. 512-454-8711
fax 512-459-8867
cell 512-415-1971
durban@pape-dawson.com
***** CONFIDENTIALITY NOTICE *****
This electronic mail transmission may be confidential,
may be privileged and should be read or retained only
by the intended recipient. If you have received this
transmission in error, please immediately notify the
sender and delete it from your system.
Snapshot
David Urban, P.E.
Project Engineer
Austin, TX 78757
ph. 512-454-8711
fax 512-459-8867
cell 512-415-1971
4 REPLIES 4
if this is the command i am think about, it basically saves and restores this position for recall later. how its used, if you change drawing orientation, you can restore it back to that location or a location of interest that you have created.
there is also another function that uses the term snapshot, and that is when you are working with blocks, and you create a slide to preview inside of symbol manager.
nzeeben
nzeeben
Hi David,
One of the ways you can use a snapshot is when dealing with landxml. If you
create a surface in civil 3d from landxml the landxml file gets treated
almost like an xref, if the landxml file were to go missing at some point
then you would find you are unable to rebuild the surface definition. The
snapshot stores the current state of the surface and allows that to be used
for future rebuilds even if the land xml file isnt available anymore.
That is one of the reasons it exists.
Nick Zeeben
Engineered Efficiency
C3D 2007
XP Tablet and Pro
"David Urban" wrote in message
news:5201804@discussion.autodesk.com...
David Urban, P.E.
Project Engineer
Austin, TX 78757
ph. 512-454-8711
fax 512-459-8867
cell 512-415-1971
Hi David,
Nick Zeeben
C3D 2007
XP Tablet and Pro
David Urban, P.E.
Project Engineer
Austin, TX 78757
ph. 512-454-8711
fax 512-459-8867
cell 512-415-1971
demus72
in reply to: nzeeben
demus72
So in my file management efforts, I chose to move the xml file to a new subfolder. My surface now shows the camera icon on the definition. How can I re-path or tell the surface where I moved the xml file to?
Thank you.
Thank you.
in reply to: demus72
Hi!
If you open Surface Properties->Definition, in the window below, you see the Operation Types that have been used to create that surface. on the Right, you see the Parameters, links for point files, xml's. There is a Browse folder icon at the end of the line, use that to change file path.
After that, Snapshot will be out of date, you might need to rebuild that too if you need that. That can be done in Toolspace->Surfaces->Expand the surface and right click on Definition->Rebuild Snapshot.
Hi!
Rail Community
