Snapping in a corridor lags
Hello
I'm a student from Belgium, now I have the problem with the snapping in a corridor.
I need it, because I need to draw a polyline to make a road with varying width.
Is there anybody with the same problem and a solution for it.
Maxim Xdrei
CivilFlow
Hello Maxim-
Try selecting your Corridor and look for the Corridor-contextual Ribbon option called "Feature Lines From Corridor":
This will allow you extract whichever feature lines you want, so that you can use snaps easier.  Also, make sure under the settings tab you do not check the Dynamic feature.  Additionally, the feature lines don't need to be in a formal Site either.
I hope this helps.
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Infrastructure Design Professional
AutoCAD Design Professional
