Slope Pattern
Slope Pattern
Slope Pattern
I would like to be able to see the corridor in diffrent colors depending if it goes on bank or ditch.
Just to see if it is Cut or fill in order to create Slope patterns. This most be a Code Set Style.
The other issue is exporting the slope pattern once it is created, how?
Please see the pic!
samir_rezk
Hi @Anonymous
Most Stock daylight subassemblies are coded with three codes (Dalylight, Daylight_Fill and Daylight_Cut) knowing this, in your Code Set Style/Points section assign a “No Display” style for the Daylight Code Featureline, then assign different color Featureline styles for each of the Daylight Cut and Fill codes.
the Corridor Properties/Slope pattern tab is additional! You can assign a Symbology using the label style composer for the Cut vs. Fill conditions.
Hope this helps,
Samir Rezk
Technical Support Specialist
Jeew-m
First you need to set the code set styles in the correct way.
Then at corridor properties --> Feature lines tab define the styles you need for cut and fill feature lines.
If you have a corridor top surface better to set the style no display otherwise you daylight feature lines may be unseen because of surface.
To extract slope patterns what I usually do is this.
Create a copy of the drawing with slope pattern.
Open the drawing. Using explode command explode the corridor twice.
After two explodes you can select slope patterns. Then use select similar to select and isolate the slope patterns.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
