Announcements
Slicing a 3D Solid with a TIN Surface
5stringb
5stringb
I'm trying to calculate a volume of soil to be removed from a dig.  I have a point cloud with ground shots from existing grade.  For the sake of simplicity, let's say I have a square box with (4) walls and a basement slab, dug into the Earth.
   Here are my steps:
  1. Create a TIN surface from the point cloud to represent existing grade - no problem.
  2. Create a 3D solid from an (around-the-walls perimeter) 2D polyline, extruded upwards by the height of the walls - no problem.
  3. Align the (uneven) existing grade TIN surface properly near the top of the walls based on a reference elevation point - no problem.
  4. Use the TIN surface to Slice off the top of the 3D solid, leaving the uneven top surface, square sides, and square bottom - Having trouble here.
I can't seem to use the TIN surface to clip the 3D solid.  Help?
I'm also open to more efficient workflows and ideas on how to accomplish, so if I'm doing this the hard way, please advise.  Thanks!
Replies (24)
neilyj666
I'm no expert on vanilla CAD Solids and Surfaces but I just MOVEd the slicing surfaces (displacement 0,0,50) which wouldn't give totally correct results but it sliced with no problem.
I think you will need to amend the slicing surface such that it is not coincident with the solid along the top
2018-11-14 14_54_09-Autodesk Civil 3D 2019 - [C__Users_NeilJ_AppData_Local_Temp_testfile for slicing.jpg
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2025 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Hi Jowenn
I tried your method in my field of aplication withour success.
Maybe I'm doing something wrong.
I would apprecaite your kindly support.
I'm using a complex TIN surface that was constructed with photogrametric fly and ReCap Photo.
ReCap gave to me a DEM file. Then I used GLobal Mapper to get the countours and finally Civil 3D to obtain the TIN surface.
The goal is to calculate the fill volume of a mobile conveyor.
Please find attached a CAD file.
Best regards.
PMP Francisco Gonzalez
francisco.gonzalezbenitez@mm.gmexico.com
...made my day.
qchenTPPXV
Thank you for sharing. Just wondering when I select from object, it doesn't show the triangle. Is there a step that I missed? Thank you for your help!
qchenTPPXV
When in the top view, I select the Tin surface and it shows as below
It shows Triangles in 3D view.
However, when I select the desired area, and hide the surface, that area doesn't show up.
Do you know any soluctions?
