Hi everyone,
I have built some models in sketch up such as viaducts, bridges and walls and imported them to civil 2016. Also i built our my roadway as a corridor. So the question is i want to see them in the same cross sections. I cant import that models to sections. Pictures will help to describe the problem.
Solved by Civil3DReminders_com. Go to Solution.
No, that would be a feature one would expect from an excellent BIM product. Unfortunately Civil 3D is not a BIM product.
If you want pictures I'd take it into Navisworks and create sections there.
Actaully you'll want to turn the Sketchup model to AutoCAD solids and then project to section views.
