Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Simple Folders in Data Shortcut
Hello, everyone! I'm in trouble when creating Data Shortcuts.
Once I build Alignments and Corridors in my source file, I organized them in folders to facilitate my navigation. Then, with the address set in Data Shortcuts Working Folder and the right folder set in Project Folder, I associate the project to the current drawing and create the data shortcut. But there's the problem: when I finish creating the data shortcut, the alignments and corridors don't come inside their folders. Also, when I create these folders in Data Shortcuts tree and drang and drop the corridors and alignments, when I open another drawing, these folders simple disappear.
Any thoughts?
Thanks!
jmayo-EE
You should be getting the folders when creating a reference. Not sure why you don't. What version are you using. Works for me on 2020. Do you have all of your updates applied/installed for AutoCAD, Map and Civil 3D?
The Datashortcuts on the toolspasce don't always refresh content when working with multiple files open in a single session or if multiple sessions are running. In Toolspace right click on the Datashortcuts and use the Refresh option. Sometime this helps without needing to restart C3D.
John Mayo
@jmayo-EE Even refreshing, it didn't work. And yes, my version is 2020, updated.
jmayo-EE
Did you close all sessions and files and try again?
Are you sure you have read/write permissions to this folder?
Have you tried this on another PC?
Have you tried with a different C3D project and files?
John Mayo
